Free Cad Kiri Cam
Onshape has flagged my account for possible compliance violations…If I step file to FreeCad what export file (step or stl) for use of Kiri should I use for CAM with FreeCad? …currently cutting with Kiri/g code with Nymolabs cnc router
I have done more research…and stl will run …will that work as well as the Onshape Kiri apt.? Should I use Fusion or Solid works?..trying to hold .001 in in location for match hole assembly.
you can use Onshape STL exports with custom fine resolutions and then import them into Kiri running on grid.space … you can also use the Kiri app inside Onshape and achieve the same thing. the preferences menu will allow you to turn import resolutions
thanks
sorry for the misunderstanding I have been using the Kiri apt in Onshape for a while with very good result …just worried if I have to make the move.
