As it is my first model with a curved surface, and all my previous projects have been simple cutouts with 1/8 endmill, I am not sure how to set up this work on KM.
I have thought about a Rough operation + cutout operation, but the rough operation also wants to do the holes. And I am also not sure about which bit to use for a good surface finish. I don’t have many, but I am open to suggestions to keep learning and extend my bits collection
thanks a lot Stewart! I will give it a chance in a few days, when I go to my parents’ place where the CNC is located.
About bits, I see your proposal uses the 1/8 endmill for all the operations. But the smaller holes at the end of the starfish arms are excluded. I can try to do those holes bigger, but is the endmill the best bit for the rough and contour operations? Asking out of pure ignorance
I also would need to buy new bits for 1/16 operations with the flute higher than the stock height, right? Or at least that the flute and the rest of the bit is 1/16. I have now 1/16 and 1/32 bits, but they are only 1 cm in that size. The rest of the bit is 1/8 and I cannot dig the full stock height with that bit. I tried one day by mistake and the result was not very good…
I am cutting pine wood 18mm thick. Usually my stock is 300x200x18mm. I am using a TwoTrees TTC 450.
With complex slices, the machine does crazy moves. Still figuring out why and with which complexity. Sometimes I think there is an elf inside that is checking when I leave the CNC alone. Whenever I am by the machine looking, all good. I leave the machine alone because it is a long work, and when I come back the stock has moved, the path has gone wrong, or some other error…
