Feed limits issue
XY & Z Feed limits are applied as feed rates on G0 moves. However, at least my processor (UCCNC, although I am using generic GRBL and custom macros as UCCNC is not available as a default option) ignores this, and interprets all G0 as fastest speed moves regardless as to whether a F (feed rate) is set on a G0. Is it possible to have an option to, if feed limits are applied, to have moving tool paths as G1 with the limit feed applied. Or is there another way of solving this problem?
it seems like a reasonable option to have the ability to emit G1 instead of G0 in these circumstances. do you mind filing an issue / feature request? you will be notified when I implement that change.
