Low priority. Just thinking.
The problem
- sending a gcode to a machine controller takes finite time (e.g. ~2msec for
G1 Xnn.nnnn Ynn.nnnnover a 115.2kbps serial link) - for a given feed rate, moving a very short distance takes very little time
- the time to move a short distance can be less than the time to send the next gcode
- in a sequence of many very short moves, a controller may not receive gcodes fast enough to keep acceleration planning ahead of the machine in motion
- in that case, the controller must plan decelerating moves to stop at the last available endpoint
- feed stops
- for long sequences of many tiny moves, machine feed may stop and continue by alternating small bits of motion and delays for the time required to receive & process the long sequence of many gcodes
- recurring sequences (e.g. by layer) can significantly increase the running time of an operation
Current code
KM already has a static threshold:
If I understand correctly, this will not emit g1 codes for very close points until it gets to a point which is far enough from the endpoint of the last emitted g1 code.
Suggesting
- Make “far enough” a tunable parameter
- For UI, an intuitively meaningful parameter could be
- maximum rate of gcodes/second instead of minimum distance/move – compute “far enough” from (feed rate)/(gcode rate)
- speed of link to machine controller (gcode consumer) – compute “far enough” from (feed rate)/((link speed/nominal size of a g1 code))
- Always emit a g1 feed to the exact last point before a g0 move (i.e. before disengaging tool from work)
