I am using Grid.Space to print STLs on my Ender 3 V2 and Ender 3 Pro. I changed all the settings to match my setting on Cura that I use for printing on my printers but whenever I try to print something I sliced on Grid Space I get the error “Extrude below minimum temp” Even though the Nozzle temp on Grid Space is set to 210. Not sure what setting I’m missing to make this work. My printer itself has no issues, it prints from Cura just fine.
Share the settings you are using — sounds like you need M109 or M116 to wait to reach temperature after setting it?
This is my Header gcode:
M104 S160 ; set extruder temp
M140 S{bed_temp} ; set bed temp
M190 S{bed_temp} ; wait for bed temp
G28 W ; home all without mesh bed level
BED_MESH_CALIBRATE AREA_START=%MINX%,%MINY% AREA_END=%MAXX%,%MAXY%
BED_MESH_OUTPUT
G80 ; mesh bed leveling
G90 ; set absolute positioning mode
M83 ; set relative positioning for extruder
G1 F1000 ; set feedrate
G1 Y-3.0 Z0.5 ; park outside print area
M104 S{temp} ; set extruder actual required temp
M109 S{temp} ; wait for extruder actual required temp
G1 X60.0 E9.0 ; purge line
G1 X100.0 E12.5 ; purge line
M117 Printing
