Error: VM Error: [object OBJECT]
workspace_Part_1_Chrome.kmz (356.1 KB)
workspace_Part_1_Firefox.kmz (146.2 KB)
Getting the captioned error whenever I attempt to export my Gcode. Tried in both Chrome and Firefox, same behaviour. Slicer works just fine. Did the same operation yesterday and it worked, but wanted to move the origin to the centre before cutting and ran into this error. A general web search indicated that if the error occurs in multiple browsers, it is likely not a client-side problem, so I am bringing it to your attention.
you’re using {file_name} in your macro which is not a valid substitution. but it still should not error out. so I’ve patched that in production. thanks for the report.
Thanks. Don’t know how that happened - probably just fat fingers!
