Hi
I am getting the error code: syntax error unexpected token ‘if’
I have imported my prusa mini config file so there is obviously an error in the header or footer gcode.
Has anyone come across this and able to suggest a fix?
Many thanks
Hi
Many thanks
Hi @Martyn … if you right-click and export your workspace and share it with me (email to sa @ grid dot space) I’ll find the problem.
I reviewed the converted profile and found that Prusa’s [variable]
substitution needs to be updated to use Kiri:Moto’s {variable}
substitution which is documented here
