Hey folks,
I wanted to carve/engrave a simple text based on a .png that I made in Inkscape, but no matter how much I change the settings that pop up when importing the file (blur, inverse Alpha and Co.), the end result is very pixeled. I cut blur the pixels out, but then it’s almost not recognizable any more.
I tried normal text and text I changed to a vector file, I changed the parts preferences to excellent, I tried exporting only fill and only stroke, but always the same result. I would have expected clear cut lines in the letters?
Or is there a better way to have the tool either follow the stroke-vectors or clean out what is inside the stroke or fill? Either as a V-carve or simply projecting the letters to a certain depth and have Kiri then calculate the path as if it was a .stl made in Sketchup or so…?
Thanks for your help and have a lovely day.
