Drilling operation not ending
drilling paused at bottom of last hole
workspace_flat_RH_CR_R_1_T (7).kmz (215.8 KB)
DRILL-RH-CR-R-1-T-084.nc (2.5 KB)
can you explain more about what I should be looking for?
at end of g-code the drill should rise up to the safe height and turn off the spindle …did not do that I have not inspected the g-code perhaps the machine dropped a bit…I was in the middle of cutting metal.
just looked at the g-code and the m30 is there so I do not know what happened
ignore post or delete it
