Have a simple square cup shape I am milling, and it comes out very close to perfect with just with a roughing pass and a outline pass. However there is a small problem. The end depth of the pocket is Z=1.0mm, the roughing path bottoms out at Z=1.01mm (from g-code inspection), and the outline path bottoms out at Z=1.217mm (from g-code inspection). While I can ignore the 10um error in roughing, the 0.217 mm error is outline is easy to see, even in preview. This is with a step down of 0.42mm, lowering the stepdown reduces this error, but I can’t seem to get rid of it. Also, I thought that using inside only for one pocket outline might get rid of it, but it is still there. Any advice?
RoughZvsOutlineZinPocket.kmz (399.1 KB)
