I tried to process this part. But somehow I was not able to generate reasonable milling paths. The “rough” workhorse did strange things with a detail on the outline. Any advice, which combination of operations should work?
those dashed lines on the outside of the circle should not be there. I know what’s causing them (low poly offsetting artifact) and will look at how to clean them up in the roughing op. it’s present in earlier versions of KM, too.
if I can find a clean solution, it’ll be fixed in tonight’s release.
here is a workspace that attempts to use tracing and outlining to workaround this problem.
