Cutting through cuts tabs
workspace_flat_RH_CR_R_1_T (2).kmz (297.1 KB)
workspace_flat_RH_CR_R_1_T (3).kmz (305.0 KB)
I do not remember having this problem before….
this is a new bug with “thru” layers overwriting the new “up and over” tab paths. fixed on the dev server if you want to test. https://dev.grid.space/kiri
works
workspace_flat_RH_CR_R_1_T (7).kmz (215.8 KB)
