I observed the following sporadic movements to Z Clearance in a Contour Y operation:
Any ideas what is causing this?
That is a good question. Did you set the clearance height to make that more noticeable? Can you right-click export your workspace and send the .kmz to me for analysis?
Any update on this? I am having Contour issues, where the contour is cutting down through the sides, and I am not sure why it is doing so.
The things highlighted in red should not be present within the contour.
to help me debug, please provide a .kmz workspace
I have the .kmz file ready, but gridspace said I aas not able to upload any attachments. I was trying to find a means of messaging you, but had no luck. So how do I get the .kmz file to you?
please email to [ sa at grid dot space ]
this was caused by “precision” in your workspace contour ops set to 0.1 instead of a much lower value. large values like that create artifacts at hard transitions. you can let KM compute the value from the animation setting by using 0 and increasing the animation resolution.
Thank you Stewart, you are amazing, that was the fix. ![]()
Kiri continues to impress me and its abilities…just learning its ins and outs is the key.
