Contour Feedrates Extremely Slow
Hey there. I’m running a project that involves a rough, followed by an X and Y contour. All operations achieve the desired end result, but there are multiple instance in which the calculated feedrate drops from the programmed 300 to around 4. The result is a process that takes 17 - 30 hours to complete. I’ve attached the workspace. Am I setting something wrong? I can see there have been some issues (usually FR getting faster) in the past, and that the algorithm tries to calculate optimum feed rates, but in this case the resulting value seems quite a bit too slow. Thoughts?
workspace_Lid_No_Kick.kmz (147.2 KB)
this is a bug. fixed for the next 4.2 release. and I will revisit this entirely in 4.3 since it’s still not optimal.
Thanks Stewart. I thought you might already be on that :slightly_smiling_face:. It turns out that one side of one piece is currently taking 33 hours to run LOL.
