I recently did a simple experiment. It doesn’t seem that Kiri:Moto is considering tool length. as a test, I created a tool that was 5mm long with a 3mm flute length and Kiri:Moto was happy as a clam to generate gcode to cut a part outline 50mm deep. It woudl be nice to have it behave in the same way that it considers tool diameter.
Thank you for your reply! I’m new at this and the reason for my experiment was because the last pass of my first file gleefully sent my collet into my stock. Fortunately i was working with construction foam as an insurance policy…
Good to hear no hardware was damaged. Maybe Stewart can add that in. It does seem reasonable that if you tell KM about the flute length it should use that data somewhere, and would save having to do the check manually.
