What are the best settings to use KiriMoto with a CNC lathe?
I noticed a reference to 4th axis lathe settings but can’t see anything in the latest OnShape app. Can a lathe mode and cutting bit option be added?
Happy to help develop if needed.
Cheers,
Andrew
To enable 4th axis mode, check indexed under stock. The build space xy grid will disappear and a couple of new stock operations will appear under that hover menu (index and lathe). You can re-enable the grid if you wish because a new checkbox option appears in indexed mode for this.
