Chamfer problems of a noob
So i just got my cnc 2 weeks ago and are still learning. I have made a engraveing of a flower and its great but the edges are rough and i would like to use a V-bit to chamfer the outline of the cut.
I have tryed running another rough pass with my Vbit and it did help but it is not perfect.
Is there a way to export the model after milling as an stl so that i could use trace on the outline of the cut?
If i use trace on the outline of the flower it removes alot of my engraveing.
can you share your workspace so I can see what you’re doing? files → export will produce a .kmz – let it here or email to [ sa at grid dot space ]
I’m emailing you a modified workspace using a trace + offset operation. see if that’s what you’re going for. I can also drop it here if you don’t mind sharing.
That works. Just had to use the taper instead of the 90¤ V bit i tryed :slight_smile:
Its a free model i found so im fine with shareing but i cant upload files more than 4mb here.
Thanks for the help
