I have the different parts ready for outline, but I don’t know how to tell KM that I want these horizontal lines + the vertical ones on the door. It is meant to be on MDF wood 3mm thick, and I want the lines to be 0.5mm deep.
If I draw the lines in the model, they seem to disappear when imported into KM. Any idea about how to include the lines in the project?
When I import it into KM, the lines in the house are gone. My expectation would be that I can import this csv and the lines are kept as objects themselves, even if it is necessary to import the lines on a separate file. I cheated by adding a 90º arch on the sheet origin to keep my 0,0 coordinates steady on the 2 documents, removed the lines from the shapes file and created a new file only with the lines, but importing the lines file does not have the desired effect, and I see no object in KM work area.
Once I have the lines, my idea is to outline the shapes (3mm) and on a different operation trace 1mm the lines with the V-bit.
