Hi again. Next thing:
I’ve found no “safe” small step-over to ensure area clearance, down to 25%.
When stepping down into a “3d” region (vs 2.5d straight walls), the tool path may leave an uncut remainder in the “middle” of one or several layers, then try to blow through it while clearing a lower layer.
I think it should be true that offsetting circuits can always clear area inside the outermost circuit when stepover is under 50%, without any difficult special cases.
The attached example shows alternation between leaving and clearing remainders while stepping down a tapering hole. It’s not a dramatic example because the uncut remainder never gets very substantial, but it should be a simple example/test case.
I’m working at a small scale with fragile bits, so maybe I’m complaining about remainders that most users wouldn’t care about. ?.
missing-inner-offets.kmz (101.9 KB)
