To start the CNC is above the part by 2 inches and at part center. When I execute the Gcode the machine dives straight down, at center and them runs through the material to the path starting point. This of course ruins the part.
when I use your workspace to generate gcode, this is how it starts for me. the animation reflects this and no collisions. the 1 inch clearance specified is shown in the preview. your gcode is missing the G0 Z25... move which I can’t explain. if you re-export the gcode, is it still missing? you can enable gcode preview in preferences so you can see the gcode without export/saving the file.
aha. if i execute the key sequence S, P, S, X then I can get it to omit the first move. which is puzzling. but at least repeatable. and so it shall be fixed.
