Hello, I am trying to do my first “pocket”. I want to cutout the external rectangle down to the bottom plus drilling the 7 small rectangles only 9mm deep.
If I use the “Outline” operation, I get the big rectangle cut, but also the small ones converting the pocket in a full hole. If I offset the outline, I don’t get the external rectangle to be fully cut.
The pocket operation does not seem to drill down. And I am not familiar with the Trace operation, that I have read in multiple threads that makes the trick for many operations.
What is the best way to get what I want? Here is my workspace:
workspace_basic_pocketing.kmz (382.3 KB)
And yes, I only have a 1/4 inch bit with enough depth to cut the 22 mm of my wood stock. I know it will create rounded inner edges on the small rectangles, but I am ok with it.
Thanks!
