I often cut shapes onto the ends of long pieces of stock and couldn’t work out how to cut an outline without cutting the shape off the end of the stock. What I discovered is that it’s possible to have different size tabs on the same job. Make one tab the size of the cross section of the stock, add the tab to where you want the stock to be uncut. Then change the size of the tab dimensions to add further tabs of a different size.
Love it! Thanks for sharing. Yes, you can change the size of each tab individually. I had not envisioned this, though!
