When I select the 3.175mm mill, then the part is milled as it should be. When I choose a 4 or 6mm mill, the marked areas are not milled. Could you direct me to the appropriate settings? Thank you
kiri_Jig.kmz (252.8 KB)
thanks for the workspace. Iβve found two bugs so far. Let me dig into this and get back to you.
Iβm not 100% happy with this solution, but it does the trick. using a pocket + expand.
I would like to completely refactor this code at some point. itβs not easy to fix the two bugs I found in its current state.
kiri_jig_alt.kmz (442.9 KB)
Problem solved for me. Thanks a lot
