Hi everyone,
I’m very new to CNC milling and as you might imagine I have no idea what I’m doing.
This is what confuses me and this is what I did:
I created 2D object in Inkscape (half circle image)
Imported to Kiri:Moto
Scaled the image X Y Z and got object I wanted
I used Outline to cut out the same half circle object
No g02 in the generated g-code
Is this how it should be or Im missing something? It uses linear moves to cut-out arc.
P.S I would like to say that I’m very impressed what Kiri:Moto can do (watched some tutorials online) . This is amazing piece of software. Thank you for creating it.
Thanks in advance
Bojan
when the 2D inkscape SVG is imported into KM, it becomes faceted as it gets turned into a 3D mesh / model. KM has code for FDM devices that “recovers” arcs from curves mesh surfaces, but this code has not yet been ported to the CNC mode.
Relative to CNC g codes : I have a 3 axis knee mill which uses a “fanuc like” g code format. I’ve historically used the pro E manufacturing workbench to generate code which creates g2 , g3 , and all the canned drilling cycles .
Questions follow:
1). Can you recommend closest post to use for this control ? Will this set up initialization g codes ?
If I wanted to create a custom post for my control, is there a document that explains the details on how to do this ?
By the way, I am extremely impressed with what you have done with Kiri:Motto - thank you so much.
In CNC mode, KM isn’t outputting anything really complicated like arcs (yet). So if your controller supports G0 and G1, then pretty much everything else is driven by macros (header, footer)
So I guess I would have to achieve curved shapes using tight tolerance with linear motion ?
By the way, do you have a collection of model files which you consider to be test / verification cases to test Kiri:Moto CNC functionality ? I’d be happy to machine these with my milling center using the “fanuc like” from wax (maybe aluminum) if that helps you with validating codes. And I’m sure other issues may come up that may be of concern to you related to code development.
since KM can’t support nurbs or other curved geometries natively, to achieve tighter tolerances, the STL/OBJ exports just need much denser faceting. in FDM mode, I have code that detects arcs (not splines) from a series of points and has the option of outputting arc gcodes in those cases. it’s on my TODO list to port this to CAM. but it’s only going to be as good as the interpretation from points.
thanks for the offer. I really need to create an automated test suite. and I’ve had false starts toward this in the past. given that the project is really just me, I’m limited by time and other realities. if you’re offering to collaborate to create such a set, that would be amazing.
if you wanted to take an approach similar to FDM, the you would start with the moveTo() function in the CAM export file. there employ a FIFO buffer to accumulate any series of n (usually 4 or more) cutting moves that share the same tool, speed, etc and share a center point on an arc. when a buffer contains enough arc points and then sees any non-fitting point or change in parameters, consume the buffer and emit an arc.
to validate the output of export, you could then update the parseGCode() function in Kiri’s print object to rasterize arc commands into discrete points for rendering.
then testing is just exporting a CAM ops chain to .gcode or .nc and re-importing the same file for visualization (via file → import or drag/drop onto workspace)
