With a second CR-30 in hand, I’m starting another round of printer upgrades. The knowledge gained from the first set of updates is proving highly valuable. This time I will make smaller incremental upgrades and document each individually. This should make it easier for someone to pick the modification that’s right for them.
The first upgrade is the simple addition of a linear rail for the X axis. This addresses what I think is the weakest mechanical part of the printer: the easily deflected hot end mount plate. The stock wheel mount for X is too close together, which I understand from a packaging standpoint. But it means the long lever arm of the hot end easily overcomes their weak clamping force.
Thank you for sharing. Being part lazy and mostly afraid to order the wrong part, what linear rails did you choose?
Also having watched your video I was wondering about offsetting the holes to put the head back in the same position. This is something I can work out on my own and just wondered if you had an opinion. If not when I get around to it I’ll post what I found out.
If you want to stick with the stock plate, you can’t offset the holes because then the belts won’t fit anymore.
My second video in this series will offer a custom plate in two varieties. One will fit the stock hot end and the other is designed for a volcano all-metal hot end upgrade. Due to the forces required to hold the stock hot end, however, that custom plate must be milled out of metal. If you upgrade the hot end to a volcano, then the plate can be printed since it uses the pillow block holes so securely mount the hot end.
it can’t hurt. but this is intended to be an easy upgrade without a lot of special tools. also, I don’t think adding more decimals to this upgrade will make a measurable difference.
@stewart I love that you are breaking it down upgrade by upgrade to see what is the most beneficial. super cool and appreciated. I was wondering if you were using Ideamaker for your slicer and if you’d be willing to share your profile. That sign you had posted was so sharp.
