Animate cut model too dark
When you do a animate to see how the model cuts, its way too dark and transparent to properly see exactly what going on.
It used to be a dark semi transparent grey. But in Ver. 4.0.26 its bluish. Still way to dark and transparent to properly see the actual cutting. Can there be a setting to up the light level and make it solid instead of transparent? It should be as bright and clear as the original model.
I’ll add a configuration option
Sounds good, thank you.
