Alternative hotend assembly and cooling?
While I found that the stock cooler worked quite well, I was so used to the focused cooling that you are referring to here. I’m using this: https://main.eva-3d.page/
But be aware that you need to modify the X-axis (and parts of the hotend assembly)to be able to mount it on the Gridbot.
Edit: And I am about to build siegfried’s solution as I find it very compelling :slight_smile:
