My environment:
- running under Onshape
- no drag 'n drop available, so maybe it works fine there.
Steps:
export a profile and check “include workspace”
later, use shift-click on “import”, to retrieve this profile/workspace; this works fine.
delete the part
use shift-click-import again, for the same file – no part is populated.
repeated import attempts don’t work any better.
use shift-click-import to bring in a different profile/workspace; this works fine.
again, delete the part and re-import, and observe failure again.
