Machining a clock pinion
I am trying to machine a clock pinion on my CNC mill with rotary indexer - Actually I am moving the indexer with a manual input controller, so I will not use any NC code to rotate the stock around automatically for the 8 positons (so indexed will not be checked). The latest attempt is not bad with the tooth form looking better, using a ⌀ 0.95 ball cutter. For some reason the ball cutter is not machining to the root dia of ⌀ 3.15 but stops a around ⌀4.05 and there is a lot of air cutting at the start - and the current cycle time for tooth is currently 1:15. Can someone take a look at the workspace and advise what changes to make if any. Many thanks!
workspace_Centre_pinion-11.5mm(for_cutting).kmz (166.7 KB)
