# Low priority CAM feature idea
**URL:** <https://forum.grid.space/t/low-priority-cam-feature-idea/657>\
**Category:** CAM\
**Created:** [May 17, 2022, 1:19am UTC](https://forum.grid.space/t/low-priority-cam-feature-idea/657 "2022-05-17T01:19:33Z")\
**Posts on this page:** 1\
**Showing post:** 3
<div class="post-metadata">
**Author:** ![pmc](https://forum.grid.space/letter_avatar_proxy/v4/letter/p/e9c0ed/32.png) [@pmc](https://forum.grid.space/u/pmc)\
**Post date:** [May 30, 2022, 2:42am UTC](https://forum.grid.space/t/low-priority-cam-feature-idea/657/3 "2022-05-30T02:42:01Z")
</div>
Just had another thought about this. Which might also solve ops/parts ordering.
Maybe generalize “pause” into something like “checkpoint”, which may or may not generate a pause.
The main idea would be that a “checkpoint” forces the end of a block of work to sort. So instead of exposing and adding controls for how K:M sorts work – especially in regard to running all ops for each part vs all parts for each op – only require that all the work to be generated by the ops before a checkpoint gets done before continuing beyond the checkpoint.
A checkpoint could have a switch to generate a pause/hold, or not. Or for greater generality: a free text field to inline into the output – which could default to {lift Z, pause, return Z}.
_[View the full topic](https://forum.grid.space/t/low-priority-cam-feature-idea/657)._
