Hi all,
I was wondering if there is anyway to change the Traverse speed in KM when roughing with heavy cuts.
This seems to be a problem related to circular tool paths.
The problem I have is during roughing out the cutter moves laterally to the next cut at the full traverse speed.
Setting the max traverse speed does overcome this problem but slows all traverse movements and makes the job run time excessive.
The engage factor slow the whole new cut feed rate but has little effect on the lateral movement speed.
Maybe I’ve got something set wrong?? I’d be grateful of any advice.
